Brwmogazos
Hello all
Been ages since my Mach 2 GT unit broke down and i havent had time to check whats wrong with it.
I think i should get it repaired as soon as i can so that either i can get clocking again or sell it(doubt).
Last time Phil told me my unit might have a leak.
If i remember well, my father while my rig was working turned down the electricity.
My pc wouldnt boot right after so i had to unplug a few plugs and put them back on so everything was fine.
(dunno if that had any effect on my rig-mk2 gt)
Finally few weeks later i turned on my rig just to find out it wouldnt boot
The evaporator temps would drop down to say 20C and then nothing...
After minutes of waiting the unit gave me the message TOO SLOW and turned itself off.
Tried several times and the same thing happened.
Took the evap head off and turned it back on and icicles would form in the evaps head but they werent that many as other times i used in the past.
Anyone got a clue whats up with my unit?
Is Nventiv up and running again?i ve been "away" for a long time so i got no idea whats happened ever since.
I spoke to hipro5 (some of you may know him from XS etc) and he told me to take it over at his house to have a look at it and he would sort it out hopefully and probably regass it with R507a(iirc) for max performance...its been ages till then and i havent contacted him for ages now so i am a bit worried if ill ever be able to repair my unit.Thing is i dont live in the UK any longer...
thanks in advance.
thanks in advance.
