Mach II gt hickup..whats up with this?
BOA279
Here is the run down. Ive got a a8n32-sli with an FX-60 and 2 gigs ram. Everything ran great for about a week but now its doing somthing fishy. Startup is perfect and while its running there is no problem. However, now when I shut windows down it no longer shuts the computer off. Windows does its shut off thing and then the screen goes black like its shut off but the monitor light is constant amber and the entire pc still runs. Shutting off the pc power supply obviously shuts the computer off which shuts the mach down. Not a real big deal...just a pain. I know I've read somewhere about the mach firmware being corrupted but Im not sure if thats the case. THANKS IN ADVANCE!
Firstly I would reflash your firmware but also make sure all your cables are still plugged in correctly
Where do i get the firmware? Also, i don't think its the connections as it starts the way its supposed to....any other Idea's anyone?
your the man...I flashed and now everything works like a champ. I even had problems with control center before (could not adjust fan speed) and all works as it should. Thanks fatty. BOA
