imported_pancake
got my mach installed on my x24800 but having some troubles. as soon as i plug a power lead into the back of the mach it starts running with red and both orange lights on. the display reads "boot loading waiting" all the time. managed to get pc running by pressing the on switch on my dfi mobo power button on case dosent start it. in windows the display says boot loading 0x000 ok . if i open the mach software it reads the cpu speed but then says at bottom lost connection retrying , shutting pc off the mach carries on running until i remove the power lead. also getting condensation build up around the black plastic that the evap head is in it starts were the braiding/heatshrink attaches to the evap head and spreads across it. also a little bit showing on the motherboard.
