Hey guys, litterally haven't been around for this one... indeed it was me who messed up the slot thing last week
The 8800GT's have a wide range of problems, some BIOS, some memory related etc... I managed to get mine RMA'd and refund is on the way, but I was advised via the website I got it from that I had left the shrink wrap over the heatsink which made it overheat?? lol.. not likely
Thats a much healthier score you got going on now mate, good for you... These things you just need to stick at...I have the same hardware as you, minus the GT which I've RMA'd for a newer GTS... I would have suggested the following (for info for others reading this):
- Check PCI-E slot
- Check the mobo manual for recommended installations as they vary from board to board
- Always think twice before flashing the BIOS, this can be easily checked if RMA'ing a dodgy card, and you would get your request rejected.
- Check that you have enough voltage going to your card... I saw a thread somewhere where someone had a faulty 6pin power cable and that gave strange performance
- When trouble shooting, start from the basics... if you can't remember what you've changed here or there, reset the CMOS, and take note of what you change each time something doesn't work...
Just my 10 pence chaps
Alex
