Hey guys i'm looking at upgrading some of my hardware and iv'e decided im going to take the next step from just water cooling my CPU, to watercooling my motherboard, cpu & gpu's.
Now i was going to hold off till the 900D is available in Australia but with i have in my mind for that case i'll be waiting till a little later in the year for that one so stay tuned!
So to much questions, I currently have the rig that is located in my sig, Now i'll be keeping the case (i'll be painting it) But i'll be changing the PSU to a Corsair AX1200i, And 3x GTX 680 4gb FTW+ gpu's (or may hold off if the 780 is out this month or maybe next month if reports are anything to go by)
1) So i'm wondering, I want to get a slightly thicker RAD in the top in push/pull I am looking at the Black ICE SR1 360 Radiator 54mm thick, to fit in the top to replace my AX360 rad (as im tired of the loud ass fans i have, i want to go for silence this time) Now would a 54mm fit in the roof with the rampage iv extreme? Is that the max size i can go?
2) Also when i put the 3x gpu's underwater would a XSPC RX240 Radiator in the front be sufficiant for cooling all those gpu's?
3) What is a decent pump you guys would recommend? I was looking at getting a Swiftech MCP35X2 dual pump.. But i only have experience with dual bay pump/res combo's i am not sure how you install the pump let alone where i could put it? lol. As i said i only have had experience with a res/pump combo.
4) If i go with the 680 4gb FTW+ cards i would probably get this block EK-FC680 GTX FTW - Acetal+Nickel, Does EK still suffer from the nickel issue?
As im looking at getting EK blocks for the motherboard also along with the CPU block. So these would be the blocks i am looking at.. Should i be worried?
LINKS:
GPU BLOCK: http://www.ekwb.com/shop/ek-fc680-gtx-ftw-acetal-nickel.html
CPU BLOCK: http://www.ekwb.com/shop/blocks/cpu-blocks/supremacy/ek-supremacy-elite-intel-2011.html
MOBO BLOCK: http://www.ekwb.com/shop/blocks/mot...l-x79/ek-fb-kit-re4-acetal-en-nickel-csq.html
Would i have any issues running those blocks? Even though some are Nickel and Nickel/Acetal with copper rads?
Would the rad setup be enough to cool everything excellently? I'm looking for quite but great performance (temps)
I would probably couple these fans with the radiators
But im looking for advice on the best option for the radiators i've suggested.
1) Noiseblocker NB-eLoop B12-P 120mm, PWM, 800-2000 RPM, up to 77.9 CFM, up to 28.4 dBA.
2) Noiseblocker NB-eLoop B12-2 120mm, 1300RPM, 51.1 CFM, 16.7 dBA
3) Noiseblocker NB-eLoop B12-3 120mm, 1900RPM, 71.3 CFM, 26.5 dBA
I'll be using a fan controller so the higher RPM fans can be turned down but from reports that i'm seeing the fans run at 15% less then what is advertised but are very quite. Just unclear on what fan setup out of those 3 i mentioned would be best and give me great temps.
LINKS:
