looooooooooooooooooong usb cable.
Raven
hi.
can a passive usb hub be used as a repeater between 2 5m usb cables or must it be a active hub ?
Regards
Raven
I imagine you can have quite a long USB cable before needing a power booster anywhere along the line since USB is self powered cable. You ever get it working Raven?
hasnt happened mucj yet but a 5m cable works without problem.
at the end of the month i will go out and buy me a 5m cable with built in repeater and put up the camera but will put it up EXTREMLY discrete and make sure it only shows what its supposed too.
Uh oh, ur not setting up a secret bathroom cam are ya? ;) Where are you putting this cam though, I'm interested to know, lol... You'll hafta gimme the IP :cool:
lmao no bathroom cam.
will put it somewhere in my kitchen so i can keep an eye on my moped.
but will make sure it only shows my moped and not the lawn as some of my neighbours sometimes are out there, gives less trouble incase as what im going to do is illegal.
the area i live in is generally okay but not far from where i live is a bunch of rehabilitationhomes for drugabusers which tends to attract bad people.
im also fixing up the moped which will make it look much better which also wont help.
Ahhh, it's a security cam then. Good show. Hope it all works out for ya!
I'm currently using my cam for a 24/7 stream of my sexy laptop :D hehe
applecam.fragtek.com :D
heres mine http://83.248.167.153:8080/
the small blurry things are 5-10mm long and 3-6cm from the camera.
will se if i can mount the camera in the airvent, already talked to the "super intendent" about the camera and he would make sure the bush doesnt grow to much.
Nice mate! Doesn't WebCamXP friggin r0x0r b0x0rz? I love it! Such a great app.
webcamxp is easy to setup, i didnt even had it installed 15minuts ago.
but going to get me another webcam, this one only has around 0.3mp.
will get one iwth 1.3mp instead.
contacted the store and they said it was true 1.3mp and not interpolated but couldnt tell me if it could record with 1.3mp which is interesting for me and my fishes, need to check it up.
n
tobad 1mbit upload doesnt go far for a broadcast.
n
Yeah mine can start to struggle a bit with a 2.5mb upstream when i get a few viewers online. I may talk to Jim and see if he would be willing to setup WebCamXP Server on one of our OC3D servers so that we can relay the stream through a connection with nearly unlimited bandwidth :)
Me and Hyper tuned in to watch Fragtek show off his MAC skills for a little while. Damn hilarious, every1 should tune into it and watch fraggles photoshop, kill his own team on COD2 and just generally be a crazy ass mofo! :beerchug:
might not be a problem for me next year, my isp is experimenting with 100/100 :D and the pricetag i heard it might get is what i used to pay for 8/1 1 month ago.
Yeah I've seen a few countries that are offering 100/100 connections for uber cheap. Hope it works out for you mate, I would love to be able to hook up to something such as that!
me hope too but also feels ridicoulous.
its rarely i go above 2mbit down so even 8mbit down is far more than i often have any use for but a higher upload wouldnt be bad to have but 100/100.
thats one cd every 58-59seconds.
the positive side is if it comes my isp will cut prices even more on the lower speeds.
pay 46$ as it is now.
Excellent
