Looking for a power Supply
Lukeovcas
Hey guys,
I'm looking for a new PSU for my new rig and just wondering if there's any that you recommend. I need one that's around 750W - 900w and is rated either 80+ silver or gold. I would like to spend £100 but can spend a bit more.
AX850 sounds about right
Something tell's me I should get the AX850. But, for £40 cheaper I can get the 750W Corsair HX Series Modular power supply? What are you thoughts on this. I'm using it to only power a i5 2500k and I'll be purchasing a new Nvidia or ATI card when they come out probably a GTX 670, If that's what they're going to be called, which I would imagine is close the the power consumption of the current 570.
Seasonic X-850 80Plus Gold 850W or Corsair AX850. Whichever is cheaper, since they are the same PSU just different labels.
