http://forums.creative.com/creativelabs/board/message?board.id=speakers&message.id=10669
yes, its by me.
have a read, see what you think.
yes, its by me.
name='Ham' said:If they blew up in less than a year, why didn't you RMA them too scan?
name='weihk' said:a amp that i can get signals from computer.....
and a Sub thats.....ermmmm.......can produce DEEP DEEP bass?
and i still have 7 of these little speakers that i hope to re-use if possible.
and the problem is.....these speakers uses 'plugs'? and most amps use bare wires and clips/screw in?
name='Yeungster' said:Call trading standards. They will be able to give you lots of good advice, including legal advice
name='Toxcity' said:Can't you just can the plug off and strip the wire so you can connect to a normal amp?
But be care to not over watt the speakers.. or you will end up blowing them.![]()
Mod's Note: Please leave out the advisor name in the future when posting.
I'll try and see if I can get someone to check this for you but it's over the weekend now, so the earliest will be on Monday.
name='weihk' said:i cant be arsed really
name='weihk' said:ahhhhhh...........cut off plug! AH-HA! see, thats why i mean by i have no idea in these stuff! LOL
mmmmm.......i need to find out how much power these little speakers can take.....
