Liquid Cooled Extreme Bitfenix Prodigy
dondoton
Bitfenix Prodigy (White)
Intel Core i7-3770K Ivy Bridge
ASUS P8Z77-I Deluxe
EVGA Geforce GTX 670
Mushkin Enhanced Blackline 8GB (2 x 4GB) 2000
Seagate Barracuda 500GB
CORSAIR Professional Series Hx650
XSPC EX240 Dual 120mm Low Profile Split Fin Radiator
Phobya Xtreme 200mm Radiator
EK GeForce 670 GTX VGA Liquid Cooling Block - Acrylic CSQ
EK Supremacy Universal CPU Liquid Cooling Block - Plexi
Swiftech MCP35X 12v PWM Controlled Water Pump - Black
Corsair Air Series AF120 Quiet Edition
Danger Den DreamFlex Value Pack
2 x 120mm Ultra Thin Flexible Fan Dust Filter (0.17mm Thick)
ModRight FilterRight 200mm Clear Aluminum Fan Filter
12" Cold Cathode Kit (Dual Ready) - Ultra Bright UV
Possibly and SSD, but I did have extreme issues with one in the past so I'm very weary of them.
First off, are the Corsair fans for the Rads? If so, you want the SP models. Also, get an SSD! A waste running all that gear and not having a SSD. Corsair, Samsung, Intel all good names. I have had great luck with OCZ ones, but some don't like them.
^+1
Also cathodes really?? LED strips - less fuss less failure. Also better lighting and more flexible with mounting. Bitfenix or NZXT make lovely looking strips or Phobya have an remote control RGB kit.
I've had luck with the Logisys UV Corner LED Light Bar, the opaque cover over the LEDs diffuses the light nicely and fit great in tight spaces. They come in 8", 16", and 24"...
