name='Hyper' said:Meh Linux, used it at college and it just seems soo complicated.
like anything really, hard to start with, then you get used to it. I was really impressed with the content filtering we set up. So easy and powerful! o and free!
name='nathan' said:like anything really, hard to start with, then you get used to it. I was really impressed with the content filtering we set up. So easy and powerful! o and free!
--- hmm u usin the flash plugin or the gnash plugin ... i have never seen this it could be a configuration specific issue --- mayb your graphs + compizname='ionicle' said:it downloaded a plugin, but if i pause a video, and restart it, it just goes grey, somtimes it doesnt load at all, it just...idk.,...doesnt work properly
and i am looking that up now, looks good, but on the download screen, ubuntu is not listed, howeber "Kubuntu" is, is this the same thing? will it work?
so make a folder, to make folders in, for each network file, seems simple enough...
done, but the server doesnt have a password, so i just delited what you put where you put *serverpassword*, doesnt have a username eithr, does this matter? i just delited what you said and put that in there...will that work?
name='ionicle' said:i am currently downloading/installing amarok, and gparted...
is there anything else you recomend?
name='ionicle' said:is there a program that more closely emulates paint?
also a p2p program, perhaps like area? or limewire, but better?
perhaps a temp monitering program for processor? (coretemp?)
a DVD RIPPINg program, that takes a dvd, and makes it into a avi/mpg file of your choise of resolution?
ermm...
if i have those i think i'd be happy![]()
name='ionicle' said:i didnt know how to extend the current partition
the F@H link, does tell you how to install F@H, but it doesnt work for me, if you could do it in code, and force it through somehow perhaps?![]()
mkdir ~/Fah
cd ~/Fah
wget [url]http://www.stanford.edu/group/pandegroup/folding/release/FAH6.00beta1-Linux.tgz[/url]
tar -xvf FAH6.00beta1-Linux.tgz
chmod +x fah6
./fah6
name='ionicle' said:done, thanks loads
worked perfectly, every little thing![]()
