LED strip decision
lemonpledge
I'm looking at different led strips for my case and have narrowed it down to three . The Bitfenix , Akasa , and the frozen cpu knock off option . I'd like the 30" version too run the entire bottom or top of the case + a little up or down the sides . I'm just wondering if anyone has any first hand experience or definate oppinions on these . Thanx in advance .
BITFENIX
AKASA
FROZENCPU
The Bitfenix ones are probably the best you've listed.
They LEDs are incredibly bright. You only need 20cm or so to light up your entire case.
I would recommend getting white instead of blue though.
Colour ones bleach everything that colour, whilst whites bring out accents like blue parts on the motherboard, blue coolant, fans, braided cables...etc.
I assumed people would go for the Bitfenix . I was just trying to save a few bux if possible but not to the point of decreasing the quality of the final build . I agree with you on the way the coloured led's can bleach out but I'm painting the frame white and all my fans are non-led's so maybe if I shorten up the lengths a bit the final effect will still be good ??
lol they are no different when they are in strips cause you hide them away ? its about the light effects for me anyway.. these led's i can change with the remote to any colour adjust the brightness it can strobe through all the colours or fade through them all, and the white is bright white aswell
