Led Fan
EmmEff
I'm looking for a decent 120mm intake fan that I will be fitting to the front of my rig. I want one with LED light on it, and I want the LED to change colour according to fan speed, preferably blue to red.
Any suggestions? Is there such a thing?
Sounds tacky to me mate. If you find one please dont post a link. I want to protect other members from the chavi tackiness!
Lol you always manage to put it so bluntly Tom! xD
Anyway, 'LED colour changing' and 'decent quality' rarely goes hand in hand with fans, usually you get one or the other.
Easy Guvnor, that was sledge hammer subtlety! :o
I wanted to link it to Corsair H100i so that I could see when my CPU was running hot. However, I think judging by the replies I might be being a bit OTT here. :lol:
Cheers.
I have to agree and say that the multi coloured stuff does sound really tacky. That said, Bitfenix spectre pro LED are very nice LED fans
Cheers.
Simple fix build it right so it doesnt get 'hot' when your not stressing the arse out of it and expect it to get warm anyways.... LOL
you could mod a corsair link strip around a white or clear fan..
that would do the trick.....it could be set up to change according to temps as well.....
