Counter-Strike: Source Client
Some of you may have noticed that the latest Steam update has made your FPS drop majorly, this is happening for people with GeForce FX cards and Radeons under the 9600. To get your FPS back follow do this:
1. Go to your Play Games on Steam
2. Right click on Counter-Strike: Source and click Properties
3. Click Launch Options and then in that box type this in it
"-dxlevel 80"
4. Now start up your CS:S and if it is still lagging go back and change the command to "-dxlevel 70".
Counter-Strike: Source Server, 'srcds'
If you are running Mani Mod and you update your CS:S Server (Linux and Windows versions) your server will fail to start. To fix this patch Mani Mod with the latest version which you can download here.
VAC is having issues in this update and is enabled on all servers even though they are saying they are not secured. Let's see how many hackers get banned because they think the servers they are going on aren't secure
"-dxlevel 80"
