hi all, (this is the second time of typing cause i accidentally click the "go back" button on my mouse.)
i was editing a video for the college promo video in premiere, just starting off editing, and while editing, ever since i started, i have noticed that the footage can be supper laggy and frame dropping to less that 10fps at times, and on other times, when it cuts to a different shot, it wont play the video all together, it just plays the background music i added on a different layer. i am using footage the a recently converted from MOV to MP4, so could it be something wrong with the footage. if so. how do i fix it. sorry if i miss some stuff, i dont feel like typing it all again.
also, when it does lag, i do see spikes in CPU usage into the 90%, but it i time scroll(can remember the proper term) across and back onto the clip midway through, it works fine, and sometimes when i time scroll away and back to the point it will transition fine. i dont get it. pelase help.
if you have any more info you need i will reply ASAP.
Thanks in advance.
System Spec:
CPU: i5 4670k
GPU: GTX 760 2Gb
Ram: 8Gb G-Skill RipJaw 1600Mhz
OS: Windows 8.1
Premiere Pro CC
Thanks in advance.
System Spec:
CPU: i5 4670k
GPU: GTX 760 2Gb
OS: Windows 8.1
Premiere Pro CC
