I reckon the main reason it's considered dated is that it still has 4x non removable 5.25" drive bays. I still use 2 of them as I have a manual fan controller and a bluray writer. Tech has moved on so even 3.5" hard disks are less common now. It's all about nvme m.2 these days. I'm still rocking 6x full size hard drives and an old sata ssd.Someone told me the other day that the Primo was outdated. BAH! It's still one of the best cases out there for watercooling.
The only gripes that I have with the primo are the side panel windows are definitely crap vs the tempered glass ones you can get on newer cases and the weight of the thing.
I've been looking at a vega 56 + EK block and a seasonic prime platinum 750w psu for the last week, but haven't been able to make up my mind.
Yes at present both my monitors are 24" 1920x1200. Future plan would be to have a 27" 2560x1440 panel but that's a long way off as panel tech hasn't really improved at all (if anything, QC has gotten worse) and the cost of a high quality 27" wide gamut panel is eye watering.
Still undecided on the GPU, do I go 56 at £390 or 64 at £456? Those are 2 year warranty powercolor cards. Or do I go for the gigabyte 56 with a 3 year warranty at £410? I had a powercolor x850XT PE in the long distant past without any issues.
Well I umm'ed and ahh'd for a long time last night and finally decided that I'd save the £20 and go with the powercolor 56, the EK copper + acetal full cover block and the seasonic 750 prime platinum. Annoyingly, I'll lose all my fancy braided cables as they are hardwired on the corsair TX650 I'm currently using.The Gigabyte Vega 64 model sounds like the best value at £410. That's excellent value in fact.
And yeah, monitors are crap right now. Since I bought my 1440p panel over two years ago, neither quality control not pricing have improved. Monitor manufacturers are doing a terrible job producing good quality monitors at reasonable prices. It's one of the biggest issue, IMO, in the gaming hardware sector, far worse than the RAM pricing.
Yeah, the monitor debacle right now is completely bonkers. I would have liked a 27" 2560x1440 10 bit wide gamut IPS or VA panel with freesync and a decent response time. Such a device doesn't exist yet which is really annoying. If I scrapped the need for wide gamut, it would be significantly easier to find something to suit.
I've still got plenty of the paracord that I used to sleeve the cables on the corsair so I could in theory just make up a set of extensions. Problem is I remember how tediously long and painful it was doing it before, well, that and the fact that I broke the pin extraction tool whilst doing the last pcie cable. The eagle eyed either never said anything or nobody noticed that two of the wires on my 8 pin pcie cable are still black braided rather than blue.It's a shame your cables won't work. It would be nice if all PSUs had the same pinouts. It would make things so much easier. I need to get round to buying new cables for my new build. It's expensive, but it's worth it when it's done right. I'd rather spend the money on the cables than a 1080Ti. Some people think that's madness, but I like it.
