Hey all,
I'll admit up front that I'm 'all the gear - no idea'... or only a little idea anyway!
Just got a machine built as below -
Corsair Carbide 500R (upper drive cage removed as only using x1 mechanical and x1 SSD)
i7-3770K (@ 3.9GHz)
H100 in the roof
16GB DDR3/1866mhz RAM
Asus Sabertooth Intel Z77
2x GeForce GTX 690 4GB
I've got the original fans (x2) as intakes up front, SHARKOON Eagle SE Ultra Slient Modular Fans (x2) as side intakes and the same again on the rad pulling air from inside the case and out and finally one SHARKOON on the rear as an INTAKE (I was advised this would be better than having it as the usual exhaust).
So the problem is I'm running pretty hot; playing FarCry 3 (2560x1440, ultra/high) for 25mins got my GPU's up to 84'c (and noisy!) and my cores were getting kinda warm too. The case was felling pretty toasty also. Any advice on the best way to get a better, cooler, airflow? Also, the 690's exhaust from both ends of the card so will this be messing up the flow of air from front to top and should I swap around the rear fan to exhaust?
Any suggestions for better fans also appreciated!!! (Swap back to a 200 on the side?).
OK, think that just about covers it. Thank you in advance for holding my hand!
i7-3770K (@ 3.9GHz)
H100 in the roof
