Hi Chaps,
The last few days I have been having some strange issues with my motherboard. It started off that I removed my 2x1Gb sticks of Geil Value from it (which were at the time passing MemTest fine) to replace them with some suspected fault RAM, In the end 3 sticks were found to be faulty and one stick was found to be broken.
When I put the sticks in one at a time, only one reported errors in memtest, however when I put 2 sticks in together, memtest always reported a few failures per pass, the same thing has happened with the latest set I got (after I RMA'd the last) but this new set pass 20+ loops in a 4 stick combo on my P3 machine.
Also, since playing around memtesting the RAM, I have encountered a new problem. Each time I shut the machine down, I then have to take the CMOS battery out and turn off the mains for 10-20 seconds before I can get the machine to reboot, otherwise it will hang at the 'Lanparty nF4' splash screen before post.
As I'm sure you can imagine, this is incredibly annoying, I'm hoping and praying that someone here will know a fix!
For the record:
1.) I have changed the BIOS to several different versions (now using the one Tony from OCZ suggests)
2.) I have cleared the CMOS, several times
3.) I have stuck to 'optimized defaults'
None of the above seems to make any difference
Please help!
For the record:
Please help!
