bennywidag
Technical problem
Hi guys, i got my mobo from scorch a week or so back(SLI-DR), and have got it running in the last few days with 2x 512 VX4000 Gold OCZ
My problem is from the start, i had to boot with one stick, then insert the other stick after i had gone to the bios, it would work for a bit then happen again, and always used to be one stick. now however the other stick is doing the same thing, and i have tried some bog ddr and it does it too, just cannot boot at all, screen stays on standby, fans wizz up.
What is the problem, i think my tagan has blown, that was a 480w and i am currently using a hiper 425 . the dram power light on the mobo is off too.
opty 148
dfi sli-dr
OCZ VX4000
Seagate 200gb
Big typhoon
dvdrw+ tons of fans
xfx 7800GTX
btw, the light refuses to go to the dram found level, used to but not now
opty 148
dfi sli-dr
OCZ VX4000
Seagate 200gb
Big typhoon
dvdrw+ tons of fans
xfx 7800GTX
