dipzy Active member Oct 28, 2012 #1 hey guys, I was playing BF3 today, about 20mins ago of writing this and this started happening: And the thing is that i've been playing BF3 on the current drivers for over 4 months and had no issues.
dipzy Active member Oct 28, 2012 #4 Josh Weston said: Does this happen in other games, or just BF3? Click to expand... Doesn't happen this bad in other games apart from little stuttering but in BF3 its happening a lot today
G Goldskis45 New member Oct 28, 2012 #5 What card is it? Any overclock? how long have you had it? all that good stuff.
dipzy Active member Oct 28, 2012 #6 Goldskis45 said: What card is it? Any overclock? how long have you had it? all that good stuff. Click to expand... The card is a EVGA GTX460 1GB SC. I have never over clocked it and i've had a little over 1 year, was used when i got it.
Pr3d4t0r New member Oct 28, 2012 #7 update drivers, not betas. also might wanna re-install dx doesnt look like dead to me, more like a software issue, if possible try diffrent card in your pc, and yours on other pc.
dipzy Active member Oct 28, 2012 #8 Pr3d4t0r said: update drivers, not betas. also might wanna re-install dx doesn't look like dead to me, more like a software issue, if possible try diffrent card in your PC, and yours on other pc. Click to expand... cool, i'm currently downloading the latest drivers, the 306.97 and hopefully it fixes the issues
H Hawk New member Oct 28, 2012 #9 Ya i agree with Pr3d4t0r if the card is used and you have had it for over a year with no issues then it's very unlikely its dying. Most GPU's will die in the first 3 month it there faulty.
dipzy Active member Oct 28, 2012 #11 dugdiamond said: disable any stereoscopic drivers and retry !!! Click to expand... I've installed new drivers and its seems fine now, will monitor over the next few days if the problem returns
dipzy Active member Oct 29, 2012 #14 Pr3d4t0r said: x3 glad to hear Click to expand... CPMFW said: good for you mate glad the new driver works Click to expand... Thanks guys, i'm glad too. I was worried since i didn't have a replacement gpu if it was faulty. Now i can continue to game
