is it worth WC a 5870
blair
Hi,
Is it worth WC a 5870 i am planning on either Xfire if its is worth it or just buying a new card when its outdated what im concerned about is it will cost me £50 for a water block but then if i do Xfire i wont be able to WC the second card and also if i got a new GPU then i would have to buy another water block seems very expensive.
Plus ill void my cards warranty by removing the cooler.
If you dont oc them hard,there is no point too wc a 5870,they are running at max 70c and 75c max in x-fire under heavy load.
And the 5870 is at or over 6870 performance level.
