I just couldn't resist. I know the tests have to be over several hours with no errors but this is the closest I've got to an overclock so far. I have never taken the Dimm voltage over 2.9 volts before and always had errors occur.
It past memtest86 for ten minutes on #5 without any errors running @ 3.6Ghz, 225x16, Dimm 3.2 volts, don't know if 3.2 volts is safe for this memory but that is the max it will take or go before errors occur.
Memory timings are 2-2-2-7
Can someone tell me the max safe voltage for my CPU?
CPU it at 1.4 volts at the moment.
It all had to be done by raising the bus speed, I don't think this CPU can have the multiplier change or not.
For the past 30 minutes I have been running StressPrime orthos 2004 with no errors and Prime95with no errors.
CPU Temp is @ 63'C on Stock heat-sink and fan using Arctic Silver Ceramique.
Throttle watch is showing no TM1 throttling unless it needs to be turned on in Bios I don't know what to look for to change that.
Am I doing this the right way?
Is there anything else that I can try out to increase the overclock?
