TheF34RChannel
As above, just not the death part just yet![]()
I'm not sure what you mean, not being a native English speaker and all?
Was just saying that what the poster above my message is right. Just dont go overboard until you no longer need the 2600k anymore.
Overclock your current CPU to death!!
Hope this doesn't count as a double post? I assume it's not since it's not a copy of a previous one.
Got the GTX 970 Strix in, very nice and aggressive looking card! It's sagging though, from midway up to the front. 1) Is that harmful? 2) Any way to resolve that, if even for looks?
I've watched TTL's 980 Strix review and his wasn't sagging, he said![]()
It does count as a Double Post.. you posted twice in a row lol
If it is a slight bend then it shouldn't be a problem. If you try to bend it back at all and it seems pretty fragile or weak, then I would worry. But it's most likely a non issue. My 3 year old 7950 didn't sag at the beginning but after about 2 years i noticed it a little more. It's just gravity working over time.
Probably not, as he wouldn't be using it on a regular basis. Only for the review.
You could always route the PCI-e connectors to support the card. It would look nice and it would still work almost as well.
Well the 970 can be close to almost twice the performance of the 770 when OC'd. Have a play around with that as well. Either way enjoy your new card, hopefully Nvidia does release some sort of fix for the memory. Obviously won't be able to use the whole 4gb at full speed, just want them to reserve that slow ram for something like Windows or something and not give games access to it.
