i had a problem today and im not sure what it was, i asked the guy that built it if he knew but he wasnt sure, if it did it again he would look into further
anyway basically the problem was I had the pc on maybe 20 minutes, I was browsing on Firefox and it just randomly faded to a black screen and switch itself off, but it then restarted itself but didnt actually do anything? didnt get the beep or even to the HDD raid screen or past the bios screen to windows. So i switched it off again (only way i could was by holding the power button down) switched it on again and it seems fine now?! would anyone know what went wrong?!
anyway after that happened i open up that prime 95 program which i just downloaded
I ran it for 30 minutes at 4.2ghz ( i realise people run it for a number of hours but i dont have time to leave it for 24hrs yet)
I used cpuid hardware monitor to record the temps, although it seems to bring up the Max values on the fans wrongly and also on the cpu & socket, the cpu always says 60c across the board regardless lol and it always says 127c on those 2 after a while so wether the software is accurate i dont know
It never went above 61C on a core, i even used that asus program to monitor temps too which never went above 62c.
The value's currently showing are after letting it idle a couple of minutes
I would just like to know if my PC is ok and the temperatures are fine? Im fairly new to this PC stuff and it randomly switching off on me has made me a bit worried lol
sorry for the big image
