Inno3d 8800gtx bios files , does anyone have them??
name='Ham' said:
Use nibitor and save yours, bam you have the file.
Okay thanks :)
and how do i go about Backing up the Bios files?? do i have to save em on a floppy drive, because if thats the case, i cant as i dont have a floppy,seeing the PC itself is only used for gaming...i guess it could be backed up on Cd??
You save the bios file to your hard drive while in windows.
You need a dos boot disk (usualy a floppy but you can do it with usb sticks and cds) to run nvflash to instate any new bios.
Oh btw,would there be any good tutorials out there that you know of for BIOS Editing on the 8800 gtx,cheers.
Yes there most certainly is. I have it bookmarked at home.. Wait a second I think I can remember the site...
Ta Da!
I used this for tweakage, it works. I haven't flashed my max OC bios onto the card though!
Have fun
Ta Da!
Have fun
thanks for that, if im right, all i gota do is just raise the shader clock?
atm my current specs are
590/1350/950
il raise the shader to 1750? Oh btw raising the shader clock, wat life does it giv the card after the Mod effect does take place...does it weaken it at all??
