The_Governour
I want to build a desk where my pc is in it - does anyone have any build log of a similar project?
I have a mate that is a carpenter and he can do anything out of wood so that wont be a problem. I would like to WC the whole system and get some 2 x XTX or RX 480 rads in push pull and 2 XTX OR RX 360 in push pull.
Now, as this is just a thought for a project then I am still trying to figure out the layout of the system and this is where I am asking for your help and thought.
I was thinking of having the 480 rads on the sides with one side pushing in air an(left for instance) and on the other side (right) then it would push the air out of the table.
The top or front (depending how you look at it..) would have the 2 x 360 rads pushing air into the desk. In theory that would create positive air pressure and would benefit the WC or?
Thoughts? Would the mobo be at the center of the table? Where would the PSU be placed? I am open for sugestions.
I would probably hide all the cables for the fans etc.
* Forgot to mention but the top would be custom cut glass.
