IIAMA refresh 144HZ - but one time booted with lower value - question
Temple30
Hello.
My pc:
*Asus Z170-P with 6700K cpu
*Corsair 750 RM
*Gtx 1080 Ti Founder Edition
*Monitor Red Eagle IIyama 24' 1080p 144hz plugged by display port cable to GFX.
Few days ago i get power outage. Power outage was because fuse was tripped because of kitchen which was turned on in other room.
When i run pc first time on first boot ( after power outage ) refresh was normal at start 144hz.
When i manually turn off computer and turn on again,and on my second boot it happened. Refresh was lower than 144hz. To make again 144hz i turned off monitor and turn back on again.
So that was bug or that power outage related?
But i like i said on my first pc run ( boot ) after power outage refresh was 144hz fine. It happened just after i normally shutdown my pc and booted pc second time.
Maybe coincidence and i am worrying for nothing,hehe ?
So conclusion: It happened not just after ( not on pc first power on ) power outage.
But on second time ( second turn ) when i boot to Windows 10.
PS: I tried to reproduce only 3 times by cutting power to pc and powering on and booting again, but 144hz on start. Not able to reproduce.
Maybe coincidence and i am worrying for nothing?
When I first bought my PG279Q which I run at 144Hz for the most part (sometimes 165), I experienced a similar issue to you whereby the refresh rate would lock at 85Hz and there was nothing I could do.
After a bit of digging, I found similar problems around the web with the common culprit being the Asus supplied DisplayPort cable. I had a spare from a top-end Dell panel that was fitted with ferrite chokes and swapped them out. Never had the issue since.
Might not be your issue but if you've got access to a high quality cable to swap or borrow to test, try that first.
Yep I had the same issue. But it really depends on the graphics card, as a GTX 970 would run 144 Hz with that Asus cable just fine, but a 980 Ti wouldn't. HAd to buy a certified 4K ready DP cable. And the reason for that whole problem, is there just isn't enough copper in the cable.
Totally agree. The difference in thickness and heft between the Asus and Dell cables was remarkable. I was left a little disappointed that such a low quality cable was bundled with an £800 Asus screen, even more so given the lower cost of the Dell screen and cable. If they can manage it on their margins, I'm sure Asus could.
