i7 7700 temperature
sristrixoc
Hi. im new here. i just build a new pc.
i7 7700 + masterliquid lite + 1070 oc strix
recently played few games gta 5, far cry primal, witcher 3
play game time
pch temperature max reach up to 65
cpu temp max reach up to 70
gpu max 65
is this temperature range correct?
Have you changed the CPU Vcore?
What are the fans doing at load?
Many many questions need answering about your config tbh
These cores can get really hot, check the cooler is seated ok, maybe set your Vcore to a static 1.24 rather than having it on auto.
Yeah, set that to 1.24 in the UEFI, anyhow the temps you have aren't that bad, so you could just leave it be if you aren't that fussed.
