Hi
I was wondering if you could help me with picking out hardware for a gaming pc.
I plan to bould my first gaming pc. I can´t decide on what type of hardwere to choose I asked my LAN-friends
but they are all very picky about hardware and argue alot about it. So I am asking alot of hardware reviewers
on youtube what they would put into a gaming pc. This will not be a dream gaming pc because that would make me broke.
If I were to buy all the top of the line hardware. I have made lists on websites that I would like to put in to a pc
and the prize was thousands of dollors that I cannot afford. So nothing to expencive but not to cheap.
I have narrowed down 4 manufacturors of motherboards that are:
GIGABYTE
EVGA
ASUS
MSI
I am not picky about the chipset.
With memory I pretty much don´t care about brand just something that works.
I don´t care about the core intel or AMD.
Graphic cards - any type. I may buy a 3D vision monitor and a 3D vision set. Depending on what type of graphic card
you recommend.
Power supply I have chosen to use the corsair AX 1200W.
The case I am going to be using is a modified ANTECH 1200 with watercooling. I have two 360 radiatiors from EK,
an EK suprieme HF and a Swiftech pump MCP655.
I am going to be using bitspower fittings 1/2"
I am going to buy waterblocks for the graphic cards that you would recommend and I might watercool the motherboard
depending on the chipset and manufacturer.
If you can halp me with this list I will be very grateful,
joman160.
GIGABYTE
EVGA
ASUS
MSI
you recommend.
joman160.
