Thelosouvlakia
Classy-Fried-Chicken
If i read correctly for I can plug in the two fans with the water cooler into the motor with a splitter and the other 3 I can plug in to the mobo... that is if I read everything correctly lol
EDIT: On a side note; is this setup good for Photoshop picture editing?
You can plug the pump(motor) in the CPU_FAN1 header on the motherboard and then use a slpitter to power the two radiator fans by plugging them in into the CPU_OP fan header the motherboard had
Yes the CPU will do picture editing, quite smoothly.
