I installed a sound pack, and for the current league MGHJ will be entering, we aren't aloud to have sounds. I need a way to remove them, does anyone know how? or is it different for every sound pack?
No... if you'de like to make sure it doesn't delete all your downloaded sounds, you can just go into that folder and delete weapons, i'm 90% sure it does not do that. Even if it did, I'm sure there is somewhere to re-download the sounds.
EDIT: Just tested. NO it does not remove the old sounds and it automatically reverts to default works perfect.
That folder doesnt contain default sounds, alot of them are stored out of your delete-finger reach. Anything in your sounds / materials / model / resource etc folder will overwrite the specific default file it is designed to. You can delete the whole folder and it wont cause any harm
