How to make Your GPU go POP without voiding warranty
Status
Not open for further replies.
kk 1...2...skip a few...50! BUTTONS! nope still working
You're a working!
You could add another fan and overvolt it [the fan], pop it, then go back to stock?
You're a working!
ill try using furmark overnight with prime running = big temps hopefully it will get friend, if that was the case the shop would have no option but to take it back would they if it was at stock at the time of death
prime wont help heat the gfx too much but override the fan profile using your fav tool,eg afterburner,set it as low as possible,THEN run furmark overnight.
Or just sell the card!
Really guys? I'm sure some of our vendor members here wouldn't appreciate a thread like this. Please don't post this sort of thing again.
-locked-
Status
