How to get IBM motherboard driver/CD
fedrorpet
Hello,
Due to some virus problem, i had formatted my desktop and re-install windows XP professional but unfortunately i have lost my motherboard driver so please suggest me that how can i get back motherboard driver setup and from where.
name='fedrorpet' said:
Hello,
IBM will most likely have it on their site. What is the motherboard model?
Failing IBMs failing website, check out a sweet little utility called everest. Last time i looked there was a home edition, pretty much picks up all the hardware in your pc and gives you the lowdown on it, making it easy to find the drivers. Hope this helps :P
Hello Fedrorpet,
user-guides.co.uk is good site.Please visit this site.I found IBM motherboard driver CD at that site.Just go through this site.
