I Hunta x
Cant see the 6870 being held back to much, with my 5870 (nearly an identical card to the 6870) i can play on high with textures and something else on ultra fairly easy, the hold back on the card is vram tbh, i sit at around 930mb used with a minimum fps in the region of 40-45 depending on the map/player count/mode.
I know its not a great comparison as 775 vs 1366 but i could try limiting bf3 to only 2 cores and see how it performs? if it can handle it fine on 2 cores it should be ok with a C2Q as from what ive seen bf3 handles hyper threading pretty well.
EDIT: not to great apparently, 2 cores = eugh 3 = eugh 4 = pretty good 6 = perfectly smooth
