how is this case
i use evgapcgamer on everthing im not makeing any new name i use that name not just on here but all diff forums and also use that name on steam everthing i use that name im not the one 2 make a new name i keep the same name plus also i use evgapcgamer cuz im also part of egc clan platoon on battlelog run by product manager of evga jacob freeman http://battlelog.battlefield.com/bf3/platoon/2832655240980388272/
can you please use punctuation and some text formatting, your posts are pretty terrible to read.
i think the idea of painting it blue is great, but i wouldn't fancy your nickname on the side, of course you are still free to do it, but i would reconsider.
then all just have a evga logo cut out of the front were it comes off 2 get 2 the fans all use 1 140mm fan and not 2 so i can put a blue led behide it that be cool
Not a bad looking case but I'd have to get a bit dremel happy with it, the facia is simply not to my tastes and all the internal drive bays would have to go and the blue is just too much needs toning down a little. Other than that it's a customiser project waiting to be chopped up.
what. i read it 3 times, still having troubles understanding.
you want to cut an EVGA logo in the front and instead of having 2x140mm fans you will only have one to be able to put LEDs behind the cut out?
yeh what dont you understand im gona have a evga logo cut out of the front panel were the 1st 140mm fan would be ok then im gona keep the 2nd 140mm fan on top put a plexiglass type window behide it and have a blue led light so it lights up the evga logo dose that help u understand what im saying and its not just gona be all blue it will be a mix of blue and black and im gona have a big nvidia logo on the side panel were the wireing gose the logo will be in black and look some like this but bigger https://www.google.com/url?sa=i&rct...12i6cbbzRnx203Q4b744K1qg&ust=1386244161443745
yea okay, go ahead.
please mate, just basic text formatting, it doesn't take that much time.
Assuming you're using the regular QWERTY keyboard, the two buttons to the right of the M key can really help people to understand your point much more easily than reading a massive string of unpunctuated text :) If people can't understand you, they can't help you.
I hate using the word 'Meh'. But I'd call this a 'Meh' case...
I think there's better choices out there, the Corsair C70 is a nice case that doesn't break the bank.
