Back when I was playing with the I-RAM, I tried it (installing XP) on a 1GB stick and it installed fine, and could run fine, seemed stable enough.
If Windows has the space, it`ll use 2.2GB... what happens when it sees that it cant install itself fully?
I`m guessing it cuts out non-essential files which should let it run faster...
would it be possible (I dont know tons about partition management) to create a soft partition that only exists while Windows is installing, then remove the barrier to allow the rest of the space on the same partition to be used? ie...let Windows install onto what it thinks is a 1GB partition, then when a very clean install is done, tell it its on an XGB partition?
Cheers!
K
(yea, nlite and a slipstreamed CD works too, but that would be too easy)
Cheers!
K
