You can increase the vcore a fair bit more matey, but that means loadsa heat so its a ballencing act.
With your levels a bit more NB and fsb volts will help as it gets higher but I wouldnt worry about much else for the time being. 60c is the point where you sit up and take notice of the temps, if it gets there in 30seconds its gunna go way up, if it takes an hour it will probably be ok.
