How are people finding the AQZ's?
Phil Stanbridge
Just wondering how people are finding these new pumps - I'm having a few issues, primarily because they are so darn powerful, the flow actually causes the water to gurgle considerably in some cases which adds to the noise.
Got one here Phil - From Mightynimrod, unsed - who got it from you before then.
I am currently installing EXOS watercooling with my 7800's and will use the pump just before the VGA cards (for that extra umph) will report back here as soon as I have some feedback for ya.
On a side not - they run off the 12v line - will they run off the 5v instead or perhaps set-up for 7v to slow them down a bit?
Cheers
Mav
7v works out at under 50% performance compared to 12v, IIRC.
Bit too much of a drop I would have guessed
Phil if your desperate, just give me them instead :P, aswell as one of those pa160's, TDX block, Maze4 (by the way.. does that bit x850xt's? It says x800 support, no mention of x850..) and some tubing... and I'll test all you want :P
