name='Pseudonym' said:Not sure if you'll be able to burn in safe mode. Safe mode only uses a few drivers that will almost always give great stability.
Give it a try is your best bet.
name='Pseudonym' said:Might be better to put it onto flash media then. If it crashes then you only have to redo one track rather than a whole DVD. Could always transfer it to another PC and burn from there. Much more time consuming, but it might be safer.
I'm sure someone else with actual knowledge of this will come along in a bit and give you a sensible idea.
Time for CS or TF2, later.
name='Pseudonym' said:Don't know if you are only doing it because you comp is unstable, but you can edit your post to add new info rather than quadruple posting.
name='Pseudonym' said:Flash media are everywhere. I'm sure you know of them. Things like USB pens, SD cards. Basically fast, small, rewritable media. It's dirt cheap these days.
