Help! :(
GODuk
My cat knocked a can of coke over my CM STORM TRIGGER keyboard. I was out at the time. It was left to dry and all works fine except the space bar.
The central switch is fine but the two smaller switches either side don't spring back up.
Does anyone know how I can access them to clean them?
Thanks
Gently pull the space bar up in multiple places until it pops off the switches, then clean them with isopropyl alcohol or contact cleaner. Then press the space bar down evenly to pop it back in place.
