help
justin
hi,
i am really confused installing the lian li kit on my mach 2, it seems as though the lcd is in the way and i cant place in the spacers, and when i do the screen does not go behind the front bezel. Who can help me?
Are you sure you've installed the brackets good? Because if you haven't installed them good your front bezel will never fit...
