Help with new desktop build
truongvu221
Hello My name is Truong Vu and my question is is the Corsair AX760 Power supply right for my desktop I'm building right now and the system specs are
Corsair 760T Case
EVGA X79 Classified Motherboard
Intel Core I7 4930K CPU
a Noctua NH-D14 CPU Cooler
2 Asus Radeon R9 280X in crossfire
2 Samsung 840 EVO 250 GB SSD
2 WD Black Series 3TB HD
7 Corsair AF140 Quiet Edition Fans ( 2 of them are LED fans)
a LG Blu Ray Drive
a LG Super Multi DVD Drive
and also I'm still thinking about Asus Xonar Essence STX Sound Card or should I buy the STX 2
any input will be much appreciated thanks and have a terrific day
Im assuming you want to copy disks hence the 2nd optical bay and yes 760 will run it but id personally got for an 860W just to give head room and have it so the psu is not working too hard all its life.
Hope that helped
thanks
thanks so much for the quick reply and to let you know I probably won't be doing crossfire then thanks so much again for the reply
You worried about overall power coming out of your plug socket?
if your not gonna crossfire maybe for gor a 290/x and run it off of a 600W PSU
I got the ax760 psu from my friend for free and the 290/x is out of my price range at the moment so that's why I bought the Asus r9 280X which I got it for only $200 on eBay thanks so much for the suggestion though have a great day
