hi
I have a Bitfenix Survivor case
The case was built with 2 120mm fans in the front, but the air coming from them was blowing straight on to the HDD bays and making a bit of noise.
I ran tests with crysis2, First test i ran with the fans on and it came back as CPU 50c and GPU 70c @ 62FPS constant
I did the tests again with the 2 fans off and the temps were pretty much the same
So was all this air going into the case against the HDD bays not doing much?
What Ive tried now is ive put back a 200mm bitfenix in the front, and ive put 1 of the 120mm's to sit inbetween the hdd and drive bay (its a perfect fit and doesnt move) its blowing cool air all over the GPU, but is this ok to have? its not going to distrupt airflow?
Currently i have a 200mm intake, 200mm exhaust and on the rad i have a push-pull effect (inside fan blowing onto rad and other blowing out of case) + the fan blowing onto gpu
Idle temps are 26c cpu and 42c gpu
