Help picking ram for mobo
If you haven't ordered the CPU yet I'd think twice and steer towards low end i5...
Anyway, should be fine since for example Asus page says "4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/1866/1600/1333/1066 MHz ECC, Non-ECC, Un-buffered Memory", though I see no point in investing to RAM.
The only thing I have ordered so far is the cpu cooler H100, and I will only be using the pc for gaming. Which is why I thought amd would be better and cheaper. And the mobo's don't cost a fortune and have all the features I feel I need.
The gpu I would get is an amd 290 when they have better coolers.
I guess I could have explained a bit better as to what and why I am getting this pc thx for the response. :)
Mobo matters little with a non-k cpu, unless you specifically need the features higher end motherboards have. Which is rare.
I don't know your budget, though, so I am merely guessing. :-P
