coalminer071
So this is my current loop run. Its pretty fugly as it is, its my first watercooling build and with acrylic tubing.
The Run goes from Rez>(upsidedown)pump>flowmeter> top of GPU, bot gpu to bottom port of quad UT60, top port of quad to Bottom of dual UT60, and then the top of the Ut60 to a dual ST30 on the front, and then back to the rez.
temps are under 40 on heaven with ambient temps of low 20s. Recently i got a crack on the acrylic pipe which made me think theres too much restriction and therefore the pump is increasing the pressure even more. Please give me some advice on how to rework the runs. Thanks.
PS. Its going to be put into parallel when i get back
Edit: xspc razor 780
