Chris230291
Member
Hello. I'm looking for some help finding a flashed base storage solution that connects via SATA and is available in small capacities (currently using a 2GB thumb drive which is ample).
At the moment the only solution i can thing of an SD to SATA converter...
Can anyone think of a better or cheaper low cost solution?
Thanks,
Chris.
Thanks,
Chris.
