Hey,
I'm somewhat of a beginner builder and I put a rig together consisting of the following components :
Phenom II x4 955 (c2)
Corsair Dominator GT 4GB kit (2 sticks) 1600MHz cl7
Asus M4A89GTD Pro
Gigabyte Radeon 6870
WD Caviar Black 500GB Sata III
Corsair 650TX PSU
So here's the deal, it normally takes a couple of tries to get the rig up and running.
When you press the power button it just kind of doesn't start up... The MoBo MEM OK led stats flashing and thats it... Eventually after giving it several tries it does fire up and makes the beep sound, tells me to enter setup since overclocking failed and so on. However sometimes it just wont start for several hours...
Seeing as the MEM OK led is flashing I thaught it could be the ram, but I was originally running a 2GB corsair dominator kit 2GB 1800MHz cl7, and now bought some dominator GT's (the 4GB kit) (with an AMD phenom II sticker on it
so I'm pretty sure it's got nothing to do with the memory.
I can't imagine what else it might be... honestly I'm out of ideas...
Another symptom if it helps anyone the CPU auto set voltage is 1,3x V and a while ago even when it started up it'd freeze at the starting windows screen, bumping it up to 1,5V seemed to fix that issue.
Everything but the CPU is just a couple of months old.
Please help, and I apologise for anything stupid I said in the text above, like said I'm not much of a pro. Same goes for any spelling mistakes.
Thanks in advance.
Asus M4A89GTD Pro
Corsair 650TX PSU
Thanks in advance.
