Heeeeeeeelp
fatty
OK Mav has told me befor but I have forgotten how do I clock up my 7800's and whats the best tool I am using 78.01 drivers I think and rivatuner but it wont lemme clock when it tests it fails grrrrrrrrrr
Have no fear Mav is here (heroic music playing in the background).
Okay go into rivatuner - click on the tab power user - ignore teh message that come up.
Look for the Overclocking options click to expand and look for diable internal clock test - all is then well and you can clock till you drop, using RIVA of course.
Good luck......................TEAM EPUK 4EVA!!
Mav
Yea Rivas always beenw eird with/for me...what do I want to see or apply to disable clock test to make it do its thing? Is it a "1"? or a yellow lightbulb? i`ve not used Riva much..I`ve always used Coolbits.
name='fatty' said:
ok found it clicked it but it wont work???? wont let me apply why the hell nooot
Place teh cursor over the disable clock test, right click on the mouse and turn the light bulb on, thats how you activate it.
Also look for disable internal clock test and again place pointer over the title right click mouse and turn the light on.
Mav
