Having problems with OCZ Vertex 3
Have you tried flashing the firmware on the drive itself?
Firmwares can be found at the ocz website under support/drivers section.
You could also check the drive in a spare or friends machine to rule out the drive itself if a firmware upgrade doesn't help.
Also have you got jumper pins on that ssd? maybe try changing them?
with my OCZ i dont know why but it would not act as a primary boot drive so i had usb, then hdd then ssd in that order to boot. works just fine maybe i was just lucky (does lucky dance... lucky lucky, lucky)
