has any one seen air spray!!!!!!
iloveamd64smum
i was in pc world yesterday and come across an aerosol can full of air...the idea i believe is to clean the dust out of the inside of your case using this can...priced at £6.99 i thought a little expensive, but what an ingenius idea.
I would think you could leave everything in your case whilst you use it!!!!!
has anyone seen it or tried it and does it work?
Yeah Kustom PC's have them in stock....very good as your components have a longer life if you get less dust in them:
http://www.kustompcs.co.uk/acatalog/info_7301.html :)
You can pick it up by the caseload super cheap at your nearest office supply store.
And as mentioned by XMS, it's much much more exciting to use it while holding the can upside down.
name='XMS' said:
Yup, many a time i have had that sprayed down the back of my trousers by fellow employees.
Unlucky! I used to take it to school and get random victims on the arm, those were the days! :D
name='kempez815' said:
Yeah a hoover does the job for me! :p
I've heard it can be quite painful...people have had to go to hospital with doing that. Remember to use the hose, not the brush
