mrDMxtreme
Hi everyone
First I'll say what I want to do and what I have as of now:
-I want to build my own system in the summer =D
-I so far I have my case (a CM HAF X) and PSU (a Corsair HX650W)
-for now i have an old HP computer that i took apart in there and a 8500GT... its shit, but that'll change in the summer
Right now the case is in this normal up-right position, but I want to put the case sideways, so that the glass side is up. I have the computer on my desk and i have the space, and i really don't need the CD drives (i never use them) plus i want to change the air flow in the case. They questions i have are:
-->since the cables are managed through the back will there be a problem? like crushing the cables??? (if so i will put together a nice "stand" that will basically support all the weight on the edges, which are strong and there won't crush the cables)
-->second i want to ask if the following arrangement of the fans make sense. (when on its side) i'll have the side 200mm fan blowing up and out (which makes sense to me cuz heat rises) and i'll have the front 230mm and top 2 200mm fans blowing in, and lastly the rear 140mm fan blowing out, since theres where the CPU cooler will be blowing the hot air.
any feedback would be great
THANKS GUYS
THANKS GUYS
